You must first onboard the VOSS device and configure any optional IQ Agent parameters before you enable IQ Agent.
- In the navigation pane, expand
- Select IQAgent.
- Select the Globals tab.
- Select the GlobalEnable check box to enable the server.
- Configure optional parameters as required.
- Select Apply.
CloudIQ Field Descriptions
Use the data in the following table to use the CloudIQ tab and to configure the ExtremeCloud IQ Agent.
Name |
Description |
Address |
Specifies the proxy IPv4 address or DNS name. |
Enable |
Specifies whether IQ Agent is enabled. The default is enabled. |
Server/Address |
Specifies the ExtremeCloud IQ DNS name. The default is hac.extremcloudiq.com. |
Password |
Specifies the proxy server username. |
TcpPort |
Specifies the TCP port. |
UserName |
Specifies the proxy server password. |
