View EAPoL session statistics to manage network performance.
Use the clear-stats command to clear EAP/NEAP statistics.
Switch:1#show eapol session-stats interface
Eap Authenticator Session Statistics
PORT MAC SESSION AUTHENTIC SESSION TERMINATE USER
NUM ID METHOD TIME CAUSE NAME
1/1 18:a9:05:b1:04:ce cb000000 remote-server 0 day(s), 05:58:16 not-terminated sachin
1/4 00:00:00:00:00:01 cb000002 remote-server 0 day(s), 05:48:01 not-terminated 000000000001
Use the data in the following table to use the show eapol session-stats interface command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
Job Aid
The following table describes the output for the show eapol session-stats interface command.
Parameter |
Description |
PORT NUM |
Displays the port number in use. |
MAC |
Displays the MAC address of the client. |
USER NAME |
Displays the user name of the Supplicant Authenticator Port Access Entity (PAE). |
SESSION ID |
Displays a unique identifier for the session. |
AUTHENTIC METHOD |
Displays the authentication method (remote or local RADIUS server) used to establish the session. |
SESSION TIME |
Displays the duration of the session (in seconds). |
TERMINATE CAUSE |
Displays the reason the session terminated. |
