Use this procedure to designate a slot in the switch for IOC Module Preconfiguration. A slot can be designated for only one module type at a time.
- Click Insert.
- Enter the slot number in the Slot field.
- Select the IOC Module type in the CardType field.
- Select the Lock field to lock the slot to the specified IOC Module type.
- Click Insert.
Card Preconfig Field Descriptions
Use the data in the following table to use the Card Preconfig tab.
| Field | Description |
| Slot | Specifies the slot number designated for pre-configuration. |
| CardType | Specifies the type of the IOC Module designated for the slot. |
| Lock | If selected, the slot is locked to only accept the type of IOC Module designated. |
