Edit the existing configuration for the RSMLT peer node in the cluster.
- Select RSMLT.
- Select the Peer tab.
- Select a cell to change the value.
- Select Apply.
Peer field descriptions
Use the data in the following table to use the Peer tab.
Name |
Description |
IfIndex |
Shows the route SMLT operation index. |
Ipv6Addr |
Configures the IPv6 address of the RSMLT interface. |
Ipv6PrefixLength |
Configures the IPv6 prefix length. |
AdminStatus |
Shows the administrative status of RSMLT on the peer. |
HoldDownTimer |
Defines how long the recovering/rebooting switch remains in a non-Layer 3 forwarding mode for the peer router MAC address. The default is 0. |
HoldDownTimeRemaining |
Indicates the time remaining in the HoldDownTimer. |
HoldUpTimer |
Defines how long the RSMLT switch maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 0. |
HoldUpTimeRemaining |
Indicates the time remaining in the HoldUpTimer. |
OperStatus |
Displays the RSMLT operating status as either up or down. |
SmltId |
Specifies the ID range for the SMLT. |
VlanId |
MacAddr |
Configures the MAC address of the VLAN. |
VrfId |
Indicates the virtual router ID to which the peer belongs. |
VrfName |
Indicates the virtual router name to which the peer belongs. |
