You cannot collect the following network statistics from a console port: the number of input and output packets, and the number of input and output bytes. All other statistics from console ports are available to assist with debugging.
Switch:1#show radius-server statistics
Responses with invalid server address: 0
Radius Server(UsedBy) : 192.0.2.58(cli)
Access Requests : 52
Access Accepts : 0
Access Rejects : 0
Bad Responses : 52
Client Retries : 52
Pending Requests : 0
Acct On Requests : 1
Acct Off Requests : 0
Acct Start Requests : 47
Acct Stop Requests : 46
Acct Interim Requests : 0
Acct Bad Responses : 94
Acct Pending Requests : 0
Acct Client Retries : 94
Access Challanges : 0
Round-trip Time :
Nas Ip Address : 192.0.2.32
Radius Server(UsedBy) : 192.0.2.58(snmp)
Access Requests : 0
Access Accepts : 0
Access Rejects : 0
Bad Responses : 0
Client Retries : 0
Acct On Requests : 0
Acct Start Requests : 0
Acct Stop Requests : 0
Acct Bad Responses : 0
Acct Client Retries : 0
Round-trip Time :
--More-- (q = quit)
Job Aid
The following table shows the field descriptions for the show radius-server statistics command output.
Parameter |
Description |
RADIUS Server |
The IP address of the RADIUS server. |
AccessRequests |
Number of access-response packets sent to the server; does not include retransmissions. |
AccessAccepts |
Number of access-accept packets, valid or invalid, received from the server. |
AccessRejects |
Number of access-reject packets, valid or invalid, received from the server. |
BadResponses |
Number of invalid access-response packets received from the server. |
PendingRequests |
Access-request packets sent to the server that have not yet received a response, or have timed out. |
ClientRetries |
Number of authentication retransmissions to the server. |
AcctOnRequests |
Number of accounting On requests sent to the server. |
AcctOffRequests |
Number of accounting Off requests sent to the server. |
AcctStartRequests |
Number of accounting Start requests sent to the server. |
AcctStopRequests |
Number of accounting Stop requests sent to the server. |
AcctInterimRequests |
Number of accounting Interim Requests sent to the server. The AcctInterimRequests counter increments only if the parameter acct-include-cli-commands is set to true. |
AcctBadResponses |
Number of Invalid Responses from the server that are discarded. |
AcctPendingRequests |
Number of requests waiting to be sent to the server. |
AcctClientRetries |
Number of retries made to this server. |
