After the optional step of uploading the apptelemetry.pol file to flash memory using Extreme Management Center, activate Application Telemetry by configuring the following:
  1. Configure the IP address of the egress interface for the GRE tunnel with the sFlow agent-ip command.
  2. Enable sFlow with the sflow enable command.
  3. Configure the IP address of the Analytics Engine with the sFlow collector 1 command.
  4. Enable Application Telemetry with the app-telemetry enable command.
The following figure shows the Application Telemetry agent on various routers and switches with packets being sent to the Analytics Engine.
Application Telemetry Overview
Table 1. Application Telemetry Legend
Number
Description
1
Analytics Engine
2
GRE tunnels
3
Application Telemetry agents
