DEMO FEATURE - NTPv4 Master Mode is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information on feature support, see VOSS Feature Support Matrix.
Perform the following procedure to set the switch to act as the Network Time Protocol (NTP) server, which means it will run in the master mode. The default value is disabled. You can also enable NTP master mode for a specific stratum.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ntp master Switch:1(config)#show ntp ========================================================================================== NTP Master ========================================================================================== Version Enabled Stratum ------------------------------------------------------------------------------------------ 4 True 11 ========================================================================================== NTP Client ========================================================================================== Version Enabled Interval Last Update Time Synchronized To ------------------------------------------------------------------------------------------ 3 False 60
The following table defines parameters for the ntp master command:
Variable |
Value |
<1-16> |
Specifies a stratum value. The default value is 10. Note:
If there is a better stratum available, it is preferred than what is configured. |
