Copy files on the internal flash.
  1. In the navigation pane, expand Configuration > Edit.
  2. Click File System.
  3. Click the Copy File tab.
  4. Edit the fields as required.
  5. Click Apply.
Copy File Field Descriptions
Use the data in the following table to use the Copy File tab.
Name
Description
Source
Identifies the device and file name to copy. You must specify the full path and filename, for example, <deviceip-ftp server>:/<filename>
Destination
Identifies the location to which to copy the source file with the filename, for example, /intflash/<filename>
Action
Starts or stops the copy process.
Result
Specifies the result of the copy process:
  • none
  • inProgress
  • success
  • fail
  • invalidSource
  • invalidDestination
  • outOfMemory
  • outOfSpace
  • fileNotFound
