Display information about BGP neighbors.
Switch:#show ip bgp neighbors vrf vrf1
BGP Neighbor Info - VRF vrf1
BGP neighbor is 200.200.200.63 remote AS 63, Internal Peer, MP-BGP-capable, BGP state [Established] UP Time 0 day(s), 07:27:24 remote router ID 63.1.1.1
vrf instance - 0
admin-state - BGP ON
connect-retry-interval - 120
ebgp-multihop - disable
hold-time - 30
keepalive-time - 10
hold-time-configured - 180
keepalive-time-configured - 60
max-prefix - 12000
nexthop-self - disable
originate-def-route - disable
MD5-authentication - disable
neighbor-debug - all
remove-private-as - disable
route-advertisement-interval - 5
route-reflector-client - disable
send-community - disable
soft-reconfiguration-in - disable
updt-source-interface - 0.0.0.0
weight - 100
Route Policy In -
Route Policy Out -
address-family vpnv4 - disable
route-refresh - disable
Total bgp neighbors - 1
The following table defines parameters for the show ip bgp neighbors command.
Variable |
Value |
{A.B.C.D} |
Specifies the IP address. |
community <enable|disable> |
Enables or disables the display of community attributes. |
longer-prefixes |
Shows long prefixes. The longer-prefixes indicate the mask length from a specified prefix to 32 (for example, show from prefix a.b.c.d/len to a.b.c./32). |
prefix/len |
Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32). |
vrf WORD<1–16> |
Specifies a VRF instance by name. |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number. |
