Use the following procedure to view IPv6 Mroute route information.
- In the navigation pane, expand the following folders: .
- Click IPv6 Mroute.
- Click the Route tab.
IPv6 Multicast Route field descriptions
Use the data in the following table to use the Route tab.
Name |
Description |
Group |
Displays the IPv6 multicast group for this entry that specifies a next hop on an outgoing interface. |
Source |
Displays the network address that, when combined with the corresponding next hop SourceMask value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
SourceMask |
Displays the network mask that, when combined with the corresponding next hop Source value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
UpStreamNeighbor |
Shows the address of the upstream neighbor from which the IPv6 datagrams from these sources are received. |
IfIndex |
Displays the slot and port number or VLAN ID for this entry. |
ExpiryTime |
Displays the minimum amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging. |
Protocol |
Displays the protocol as one of the following:
