Use the show ntp statistics command to view the following information:
number of NTP requests sent to this NTP server
number of times this NTP server updated the time
number of times the client rejected this NTP server while attempting to update the time
stratum
version
sync status
reachability
root delay
precision
The syntax for this command is as follows.
show ntp statistics
The following example shows sample command output.
Switch:1##show ntp statistics
N NTP Server : 192.0.2.187
Stratum : unknown
Version : unknown
Sync Status : unknown
Reachability : unknown
Root Delay : unknown
Precision : unknown
Access Attempts : 0
Server Synch : 0
Server Fail : 0
Fail Reason : unknown
