Use this procedure to insert a FA Zero Touch Client.
  1. In the navigation pane, expand Configuration > Edit.
  2. Click Fabric Attach.
  3. Click the Zero Touch Client Auto Attach tab.
  4. Click Insert.
    The Insert Zero Touch Client dialog box appears.
  5. In the Type field click the ellipsis and select a client. Click Ok to select the client or Refresh to update the list.
  6. In the Isid field enter the ISID value.
    The ISID value is between 0 and 16777214.
  7. Click Insert.
