Configure a PIM virtual neighbor if the next hop for a static route cannot run PIM, such as the Virtual Router Redundancy Protocol (VRRP) address on an adjacent device.
- In the navigation pane, expand the following folders: .
- Click PIM.
- Click the Virtual Neighbors tab.
- Click Insert.
- Specify the IP address of the virtual neighbor.
- Specify the interface index for the PIM interface.
- Click Insert.
Virtual Neighbors field descriptions
Use the descriptions in the following table to use the Virtual Neighbors tab.
Name |
Description |
Address |
Specifies the IP address of the neighbor. |
IfIndex |
Specifies the IP address of the PIM interface. |
