Perform this procedure to display the filter Access Control List (ACL) configuration on the switch.
enable
show filter acl
Switch:1> enable
Switch:1# show filter acl
Vlan/VSN ACL Table
Acl Type AclName PktType State Origin # of Default CtrPkt Vlan/I-sid
Id ACEs Action Rule Id
5 Ingress ACL-5 nonipv6 enabled config 0 permit permit
7 Ingress ZTC-1/5 nonipv6 enabled ztc 0 permit permit
15 Ingress ACL-15 nonipv6 enabled config 0 permit permit
Vlan ACL Global-Action Table
Acl Type Ipfix Monitor Monitor
Id Dst-Mlt Dst-Port
5 Ingress Disable 0
7 Ingress Disable 0
15 Ingress Disable 0
Port ACL Table
Acl Type AclName PktType State Origin # of Default CtrPkt Port
Id ACEs Action Rule
1 Ingress ACL-1 nonipv6 enabled config 0 permit permit
2 Ingress EapMhmvIn-1/1 nonipv6 enabled eap 0 permit permit
3 Egress EapMhmvOut-1/2 nonipv6 enabled eap 0 permit permit
4 Ingress EapMhmvInIpv6-1/3 ipv6 enabled eap 0 permit permit
6 Egress EapMhmvOutIpv6-1/4 ipv6 enabled eap 0 permit permit
2048 Ingress ACL-2048 nonipv6 enabled config 0 permit permit
Port ACL Global-Action Table
Id Dst-Mlt Dst-Port
1 Ingress Disable 0
2 Ingress Disable 0
3 Egress Disable 0
4 Ingress Disable 0
6 Egress Disable 0
2048 Ingress Disable 0
Displayed 9 of 9 Entries
