To configure a node to operate as a DvR Leaf node, you must first enable the dvr-leaf-mode boot flag.
The dvr-leaf-mode boot flag is disabled by default. You must explicitly enable this flag before you configure a switch node to operate as a Leaf node.
After you enable or disable the boot flag, you must save the configuration and reboot with the saved configuration, for the changes to take effect.
Important
A node on which the dvr-leaf-mode boot flag is enabled cannot be configured as a DvR Controller.
