View RMON statistics to manage network performance.
View RMON statistics:
show rmon stats
Switch:1(config)#show rmon stats
Rmon Ether Stats
INDEX PORT OWNER
1 1/10 monitor
Job Aid
The following table describes parameters in the output for the show rmon stats command.
Parameter |
Description |
Index |
An index that uniquely identifies an entry in the Ethernet statistics table. |
Port |
Identifies the source of the data that this entry analyzes. |
Owner |
The entity that configured this entry and is therefore using the assign resources. |
