This procedure does not apply to VSP 8600 Series and XA1400 Series.
You must enable EAPoL globally.
Perform this procedure to enable Link Layer Discovery Protocol (LLDP) authentication of IP phones. The switch authenticates the phone after it receives LLDP packets from the phone.
Auto-sense LLDP authentication applies to Auto-sense ports in the VOICE state. Auto-sense LLDP authentication does not require a global Auto-sense voice configuration.
The no auto-sense eapol voice lldp-auth command removes all Auto-sense LLDP sessions and removes the Auto-sense LLDP authentication configuration.
The system removes the LLDP session for the following reasons:
You disable EAPoL globally.
You disable Auto-sense on the port.
The LLDP neighbor is removed.
If the LLDP authentication configuration exists and one of the following situations occur, the LLDP session is recreated:
You renable EAPoL globally.
You renable Auto-sense on the port.
The LLDP neighbor is recreated.
Enabling LLDP authentication on the switch:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#auto-sense eapol voice lldp-auth
The following table defines parameters for the auto-sense eapol voice command.
Variable |
Value |
lldp-auth |
Enables LLDP authentication of IP phones. By default, LLDP authentication of IP phones is enabled on the switch. |
