Globally enable or disable EAP on the switch. By default, EAP is disabled.
Global field descriptions
Use the data in the following table to use the Global tab.
Name |
Description |
EapolVersion |
Displays the EAP version on the switch. |
AccessControl |
Enables system authentication control. EAP is disabled by default. |
NonEapRadiusPwdAttrFmt |
Specifies the password attribute format for non EAP RADIUS authentication.
NonEapRadiusPwdAttrKeyString |
Specifies the attribute key string for non EAP RADIUS password. The range is 0– 32 characters. |
ClearNonEap |
Clears the NEAP session that is learned on the switch. |
| AutoIsidOffset Note: Exception: Not
supported on VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Specifies the Auto I-SID Offset value. The range is 0-15995903. |
| AutoIsidOffsetEnable Note: Exception: Not
Series, VSP 8600
Series, or XA1400
Series.
Enables or disables the Auto I-SID Offset feature. |
