A forwarding profile is a collection of port and destination pairs. When you configure UDP forwarding list entries, be sure to first configure the UDP forwarding list. Then, configure your UDP forwarding list entries and assign them to a UDP forwarding list. If you do not assign a UDP forwarding list entry to at least one UDP forwarding list, the UDP forwarding list is lost after a restart.
  1. In the navigation tree, expand the following folders: Configuration > IP.
  2. Click UDP Forwarding.
  3. Click the Forwarding Lists tab.
  4. Click Insert.
  5. In the Id field, type the forwarding list ID.
  6. In the Name field, type the name of the forwarding list if required.
    The forwarding list appears in the FwdIdList box.
  7. Click Insert.
Forwarding Lists field descriptions
Use the data in the following table to use the Forwarding Lists tab and Insert Forwarding Lists dialog box.
Name
Description
Id
Specifies a value that uniquely identifies this list of entries (1 to 1000).
Name
Specifies an administratively assigned name for this list (0 to 15 characters).
FwdIdList
Specifies the zero or more port forwarding entries associated with this list. Each list identifier is stored as 2 bytes in this array, starting from 0 bytes (size=64). Clicking on the ellipsis (...) button in this field displays the ID list.
