Configure system message control to suppress duplicate error messages on the console, and to determine the action to take if they occur.
Switch:1> enable
Switch:1# configure terminal
Configure system message control to suppress duplicate error messages on the console and send a trap notification:
Switch:1(config)# sys msg-control action both
Configure the number of occurrences of a message after which the control action occurs:
Switch:1(config)# sys msg-control max–msg–num 2
Configure the message control interval in minutes:
Switch:1(config)# sys msg-control control–interval 3
Enable message control:
The following table defines parameters for the sys msg-control command.
Variable |
Value |
action <both|send-trap|suppress-msg> |
Configures the message control action. You can either suppress the message or send a trap notification, or both. The default is suppress. |
control-interval <1-30> |
Configures the message control interval in minutes. The valid options are 1–30. The default is 5. |
max-msg-num <2-500> |
Configures the number of occurrences of a message after which the control action occurs. To configure the maximum number of occurrences, enter a value from 2–500. The default is 5. |
