Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
Switch:1#show ip ospf ifstats
OSPF Interface Statistics - GlobalRouter
---HELLOS---- ---DBS--- -LS REQ-- --LS UPD--- --LS ACK---
INTERFACE RX TX RX TX RX TX RX TX RX Tx
192.0.2.3 76035 76355 33 32 4 9 2483 2551 2525 1247
192.0.2.8 76038 76349 0 0 0 0 0 0 0 0
Use this table to help you use the show ip ospf ifstats command.
Variable |
Value |
detail |
Shows detailed information. |
mismatch |
Shows the number of times the area ID is not matched. |
vlan <1-4059> |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-512> |
Specifies a VRF or range of VRFs by ID. |
Job Aid
The following table describes the output for the show ip ospf ifstats command.
Field |
Description |
INTERFACE |
Indicates the IP address of the host. |
HELLOS RX |
Indicates the number of hello packets received by this interface. |
HELLOS TX |
Indicates the number of hello packets transmitted by this interface. |
DBS RX |
Indicates the number of database descriptor packets received by this interface. |
DBS TX |
Indicates the number of database descriptor packets transmitted by this interface. |
LS REQ |
Indicates the number of link state request packets received by this interface. |
LS TX |
Indicates the number of link state request packets transmitted by this interface. |
LS UDP RX |
Indicates the number of link state update packets received by this interface. |
LS UDP TX |
Indicates the number of link state update packets transmitted by this interface. |
LS ACK RX |
Indicates the number of link state acknowledge packets received by this interface. |
LS ACK TX |
Indicates the number of link state acknowledge packets transmitted by this interface. |
VERSION |
Indicates the OSPF version. |
AREA |
Indicates the OSPF area. |
AUTHTYPE |
Indicates the OSPF authentication type. |
AUTHFAIL |
The count of authentication fail messages. |
NETMASK |
Indicates the net mask. |
HELLO |
The count of Hello messages. |
DEADTRR OPTION |
The dead TRR option. |
