Perform the following procedure to configure virtual ports to be used by the virtual service configured on the switch.
The names of Ethernet ports appearing in a specific Virtual Machine (VM) are not correlated to the configured virtual port names. Each VM renames the Ethernet ports as per its requirements, after they are discovered during the VM initialization.
By default, all virtual ports of OVS connection type appear first in the alphabetical order of their configured names, followed by the virtual ports of SR-IOV and VT-d connection types.
You must enable trunking on the Extreme Integrated Application Hosting (IAH) port when you use SR-IOV and OVS connection types.
Ensure the switch has the Ethernet drivers installed as per the SR-IOV standard, to support the VT-d and the SR-IOV connection type for the configured virtual ports.
VPorts Field Descriptions
Use data in the following table to use the VPorts tab.
Name |
Description |
Virtual Service Name |
Specifies the virtual service name. Note:
The specified name must match the virtual service name configured on the switch. |
Interface Name |
Specifies the virtual port. |
VlanIdList |
Specifies the VLAN ID to which the virtual port is assigned. |
ConnectType |
Specifies the virtual port connect type. The default is VT-d. The switch supports the following maximums for virtual ports:
Port |
Specifies the name of the Extreme Integrated Application
Hosting port
associated with the virtual port. Depending on hardware, the
switch can support the following Extreme Integrated Application
Hosting ports:
NicType |
Specifies the Virtual Port NIC type. The default
is e1000.
Note:
Configure this value only when the ConnectType field is OVS. |
