Show RSMLT information to view data about all RSMLT interfaces. The output of the command includes IPv6 information for the local and peer nodes.
If you use the show ip rsmlt command after you delete an RSMLT, the RSMLT still shows in the command output until you restart the switch.
Switch:1>show ip rsmlt
Ip Rsmlt Local Info - GlobalRouter
VID IP MAC ADMIN OPER HDTMR HUTMR
101 101.1.1.32 00:24:7f:9e:da:01 Enable Up 100 200
102 102.1.1.32 00:24:7f:9e:da:02 Enable Up 60 180
VID SMLT ID
101 101
102 102
VID IPv6 MAC ADMIN OPER HDTMR HUTMR
101 00:24:7f:9e:da:01 Enable Up 100 200
1010:0:0:0:0:0:0:0/64
1010:0:0:0:0:0:0:32/64
fe80:0:0:0:224:7fff:fe9e:da01/128
102 00:24:7f:9e:da:02 Enable Up 60 180
1020:0:0:0:0:0:0:0/64
1020:0:0:0:0:0:0:32/64
fe80:0:0:0:224:7fff:fe9e:da02/128
VID SMLT ID
101 101
102 102
Ip Rsmlt Peer Info - GlobalRouter
101 101.1.1.33 00:24:7f:9e:ea:01 Enable Up 100 200
102 102.1.1.33 00:24:7f:9e:ea:00 Enable Up 60 180
VID HDT REMAIN HUT REMAIN SMLT ID
101 60 180 101
102 60 180 102
101 00:24:7f:9e:ea:01 Enable Up 100 200
1010:0:0:0:0:0:0:33/64
fe80:0:0:0:224:7fff:fe9e:ea01/128
102 00:24:7f:9e:ea:00 Enable Up 60 180
1020:0:0:0:0:0:0:33/64
fe80:0:0:0:224:7fff:fe9e:ea00/128
101 60 180 101
102 60 180 102
Switch:1>show ip rsmlt edge-support
RSMLT Peer Info:
rsmlt-peer-forwarding : disable
Variable definitions
Use the data in the following table to use the show ip rsmlt command.
Variable |
Value |
local |
Shows local RSMLT information. |
peer |
Shows RSMLT information for the peer. |
vrf WORD<1-16> |
Shows information for a specific VRF name. |
vrfids WORD<0-512> |
Shows information for a specific VRF ID. |
