Use this procedure to graphically view IPsec statistics and counter
values for each IPsec-enabled interface.
If you select an interface on the Stats tab,
you can click Graph to graph particular statistics for that interface.
- In the navigation pane,
expand the folders.
- Click IPSec.
- Click the Interface Stats tab.
- Select a row, and click Graph.
- Select one of the parameters,
and click the appropriate icon in the upper-left corner of the menu
bar to draw a line chart, area chart, bar chart, or a pie chart.
- To clear existing counters,
and fix a reference point in time to restart the counters, click Clear Contents.
- To export the statistical
data to a file, click Export.
- To configure a poll
interval, select an appropriate value from the Poll Interval drop-down list.
