This procedure does not apply to VSP 8600 Series.
Use this task to view IPv6 ICMP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IPv6-ICMP tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IPv6-ICMP Field Descriptions
Use the data in the following table to use the IPv6-ICMP tab.
Name |
Description |
InMsgs |
Shows the inbound messages statistics. |
InErrors |
Shows the inbound errors statistics. |
InCsumErrors |
Shows the inbound checksum errors statistics. |
InDestUnreachs |
Shows the inbound destination unreachable statistics. |
InTimeExcds |
Shows the inbound time exceeded statistics. |
InParmProbs |
Shows the inbound parameter problems statistics. |
InPktTooBigs |
Shows the inbound packets too big statistics. |
InRedirects |
Shows the inbound redirects statistics. |
InEchos |
Shows the inbound echos statistics. |
InEchoReplies |
Shows the inbound echo replies statistics. |
InGroupMembQueries |
Shows the inbound group member queries statistics. |
InGroupMembResponses |
Shows the inbound group member responses statistics. |
InGroupMembReductions |
Shows the inbound group member reductions statistics. |
InRouterSolicits |
Shows the inbound router solicits statistics. |
InRouterAdvertisements |
Shows the inbound router advertisements statistics. |
InNeighborSolicits | Shows the inbound neighbor solicits statistics. |
InNeighborAdvertisements | SHows the inbound neighbor advertisements statistics. |
InMLDv2Reports | Shows the inbound MLDv2 reports statistics. |
InType134 | Shows the inbound type134 statistics. |
InType136 | Shows the inbound type136 statistics. |
OutMsgs |
Shows the outbound messages statistics. |
OutErrors |
Shows the outbound errors statistics. |
OutDestUnreachs |
Shows the outbound destination unreachable statistics. |
OutTimeExcds |
Shows the outbound time exceeded statistics. |
OutParmProbs |
Shows the outbound parameter problems statistics. |
OutPktTooBigs |
Shows the outbound packets too big statistics. |
OutRedirects |
Shows the outbound redirects statistics. |
OutEchos |
Shows the outbound echos statistics. |
OutEchoReps |
Shows the outbound echo replies statistics. |
OutGroupMembQueries |
Shows the outbound group member queries statistics. |
OutGroupMembResponses |
Shows the outbound group member responses statistics. |
OutGroupMembReductions |
Shows the outbound group member reductions statistics. |
OutRouterStatistics |
Shows the outbound router statistics |
OutRouterAdvertisements |
Shows the outbound router advertisements statistics. |
OutNeighborSolicits |
Shows the outbound neighbor solicits statistics. |
OutNeighborAdvertisements |
Shows the outbound neighbor advertisements statistics. |
OutMLDv2Reports |
Shows the outbound MLDv2 reports statistics. |
OutType133 |
Shows the outbound Type133 statistics. |
OutType135 |
Shows the outbound Type135 statistics. |
OutType143 |
Shows the outbound Type143 statistics. |
