Perform this procedure to view policy information of remote LLDP-MED on specific ports.
- Click Port MED.
- Click the Neighbor Policy tab.
Neighbor Policy Field Descriptions
Name |
Description |
TimeMark |
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Specifies the port on which the remote LLDP-MED information is received. |
Index |
Specifies the particular connection instance that is unique to the remote LLDP-MED. |
PolicyAppType |
Specifies the policy application type. |
PolicyVlanId |
Specifies the VLAN ID for the port, as defined in IEEE 802.1Q-2003. The value 0 is used if the device is using priority tagged frames, which means only the 802.1D priority level is significant, and the default VLAN ID of the ingress port is used instead. |
PolicyPriority |
Specifies the Layer 2 priority used for the specified application type, as defined in IEEE 802.1D-2004. The default value is 0. |
PolicyDscp |
Specifies the value of the Differentiated Service Code Point (DSCP) associated with a specific port on the remote LLDP-MED, as defined in IETF RFC 2474 and RFC 2475. The default value is 0. |
PolicyUnknown |
Specifies the network policy for the remote LLDP-MED is currently unknown. |
PolicyTagged |
Specifies whether the application uses a tagged or untagged VLAN, as defined by IEEE 802.1Q-2003.
