Use the following procedure to configure MSTP multiple spanning tree instance (MSTI) options.
    enable
    configure terminal
  2. Configure MSTP MSTI:
    spanning-tree mstp msti <1-63> priority <0–65535>
Switch:1(config)# spanning-tree mstp msti 62 priority 4096
Use the data in the following table to use the spanning-tree mstp msti <1-63> priority <0–65535> command.
Table 1. Variable definitions
Variable
Value
<1-63>
Specifies the instance ID.
<0–65535>
Specifies the priority value. Enter values in increments of 4096:
  • 4096
  • 8192
  • 12288
  • 16384
  • 20480
  • 24576
  • 28672
  • 32768
  • 36864
  • 40960
  • 45056
  • 49152
  • 53248
  • 57344
  • 61440
