Perform the following procedure to view information about the package files available in the /var/lib/insight/packages directory, which you can use to install a new virtual service.
- Click Virtual Service.
- Click the PackageFile tab.
PackageFile Field Descriptions
Use data in the following table to use the PackageFile tab.
Name |
Description |
Name |
Shows the name and absolute path information for package files available in the /var/lib/insight/packages directory. |
Date |
Shows the date and time when the package file was added to the directory. |
Size |
Shows the size (in bytes) of the package file. |
