Use the following procedure to enable or disable encryption on a MACsec capable port. The default is disabled.
If you disable encryption, MACsec forwards traffic in clear text. You can view that data that is not encrypted in the Ethernet frame that travels across the link. Even if you disable encryption the MACsec header applies to the frame and integrity checks make sure that traffic has not been tampered with.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  2. Enable MACsec encryption on the port:
    macsec encryption enable
  3. Disable MACsec encryption on the port:
    no macsec encryption enable
Configure MACsec encryption on a port:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabit 1/2
Switch:1(config-if)#macsec encryption enable
