Use the following procedure to remove a software build for the switch.
Important
A maximum of 6 software distributions can be installed. Once the limit is reached, one or more distributions must be removed to accommodate new distributions.
enable
software remove WORD<1-99>
Remove the software build:
Switch:1>enable Switch:1#software remove w.x.y.z
