Use the following procedure to view a the remote MAC table for a C-VLAN.
- Click VLANs.
- Click the Remote MAC tab.
Remote MAC field descriptions
Use the data in the following table to use the Remote MAC tab.
Name |
Description |
VlanId |
Indicates the VLAN ID for this MAC address. |
Addr |
Indicates the customer MAC address for which the bridge has forwarding and/or filtering information |
DestAddr |
Indicates the provider MAC address for which the bridge has forwarding and/or filtering information. |
PrimaryBVlanId |
Indicates the primary B-VLAN ID for this MAC address. |
PrimaryDestSysName |
Indicates the primary system name of the node where the MAC address entry comes from. |
PrimaryPort |
Either displays the value 0, or indicates the primary port on which a frame came from. |
SecondaryBVlanId |
Indicates the secondary B-VLAN ID for this MAC address |
SecondaryDestSysName |
Indicates the secondary system name of the node where the MAC address entry comes from. |
SecondaryPort |
Either displays the value 0, or indicates the secondary port on which a frame came from. |
SmltRemote |
Indicates the MAC address entry for the remote vIST peer. |
Status |
Indicates the status of this entry:
