This procedure does not apply to VSP 8600 Series and XA1400 Series.
Perform this procedure to configure Fabric Attach authentication for ports that are operating in Auto-sense mode.
Configuring Fabric Attach message authentication globally:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#auto-sense fa message-authentication
The following table defines parameters for the auto-sense fa command.
Variable |
Value |
authentication-key WORD<0-32> |
Specifies the authentication key value. |
message-authentication |
Enables Fabric Attach message authentication globally, for ports that operate in Auto-sense mode. |
