Change the VRF instance as required. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View.
Create a black hole static route to the destination that a router advertises to avoid routing loops when aggregating or injecting routes to other routers.
If an existing black hole route is enabled, you must first delete or disable it before you can add a regular static route to that destination.
To create a black hole static route, you must configure the NextHop address to 255.255.255.255.
When you specify a route preference, be sure to appropriately configure the preference so that when the black hole route is used, it is elected as the best route.
