Review the following limitations and behavioral characteristics associated with DvR.
The DvR feature does not affect out-of-band management on a switch chassis, if the chassis supports it.
The DvR feature does not support a non-DvR BEB in a DvR enabled Layer 2 VSN.
The number of host route records that can be stored in the datapath of a Leaf node is limited to the scaling capacity of the switch node. Different switch platforms have different scaling capacities.
For information on the scaling capacities of different platforms, see Release Notes for VOSS.
You must first disable DvR on a Controller or Leaf node, before you attempt to change the domain ID of the node.
You cannot configure IGMP snooping on DvR enabled nodes.
DvR is only supported for IPv4.
DvR is only supported in warm standby High Availability mode on the VSP 8600 Series.
