To configure the server, you must enable RESTCONF. RESTCONF is disabled by default.
After RESTCONF is enabled, you must disable RESTCONF to modify some of the RESTCONF parameters.
- In the navigation pane, expand
- Click RESTCONF.
- Click the RESTCONF tab.
- Select the GlobalEnable check box to enable the RESTCONFserver.
- Configure optional parameters as required.
- Click Apply.
RESTCONF Field Descriptions
Use the data in the following table to use the RESTCONF tab.
Name |
Description |
GlobalEnable |
Enables or disables the RESTCONF server. The default is disabled (cleared). |
TcpPort |
Specifies the TCP port to use for the RESTCONF server. The default is 8080. The RESTCONF status must be disabled before you can modify this field. |
TlsEnable |
Enables or disables TLS/SSL if you require HTTPS access to the RESTCONF server. The default is disabled. The RESTCONF status must be disabled before you can modify this field. |
CertificateFilename |
If HTTPS access is required, specifies the file name and path of the TLS/SSL certificate. The certificate file must be in the /intflash directory on the switch. |
CertificateAction |
Installs or uninstalls the TLS/SSL certificate file. It also shows the current status of the certificate installation. |
NotificationEnable |
Enables or disables trap notification when the RESTCONF server is not available. The default is enabled. |
OperStatus |
Shows the operational status of the RESTCONF server. |
WebServerVersion |
Shows the RESTCONF web server version that is running on the server. |
RestConfServerVersion |
Shows the RESTCONF server version that is running on the server. |
