Perform this procedure to view PoE information of remote LLDP-MED on specific ports.
- Click Port MED.
- Click the Neighbor PoE tab.
Neighbor PoE Field Descriptions
Name |
Description |
TimeMark |
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Specifies the port on which the remote LLDP-MED information is received. |
Index |
Specifies the particular connection instance that is unique to the remote LLDP-MED. |
PoEDeviceType |
Specifies the type of PoE LLDP-MED.
