Add or remove the ports in a VLAN to configure the ports in the VLAN.
Add ports in a VLAN:
Switch(config-if)# vlan members add 1 1/2 static
Remove ports in a VLAN:
Switch(config-if)# vlan members remove 1 1/2 notallowed
Variable definitions
Use the data in the following table to use the vlan members add and vlan members remove commands.
Variable |
Value |
<1-4059> |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
portmember |
Configures the port type as port member. |
