Configure EAP on a specific port when you do not want to apply EAP to all of the switch ports.
Configure the maximum EAP requests sent to the supplicant before timing out the session:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface GigabitEthernet 1/2 Switch:1(config-if)#eapol max-request 10 Switch:1(config-if)#eapol port 1/2 quiet-interval 500
The following table defines parameters for the eapol port command.
Variable |
Value |
{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Specifies the port or list of ports used by EAP. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
max-request <1-10> |
Specifies the maximum EAP requests sent to the supplicant before timing out the session. The default is 2. |
quiet-interval <1-65535> |
Specifies the time interval in seconds between the authentication failure and start of a new authentication. The default is 60. |
re-authentication enable |
Enables reauthentication of an existing supplicant at a specified time interval. |
re-authentication-period <1-65535> |
Specifies the time interval in seconds between successive reauthentications. The default is 3600 (1 hour). Note:
The EAP re-authentication period value is between 1–65535. Early releases support up to 2147483647. To maintain backward compatibility the CLI value is between 1–2147483647. Trying to configure above 65535 results in an error. |
status {authorized|auto} |
Specifies the desired EAP authentication status for this port. |
