Use this procedure to configure the global IPv6 PIM-SM parameters on the switch.
Switch:1(config)#show ipv6 pim
Pim General Group - GlobalRouter
PimStat : disabled
Mode : sparse
StaticRP : disabled
FwdCacheTimeout : 210
DiscDataTimeout : 60
RegSupprTimeout : 60
UniRouteChangeTimeout : 5
JoinPruneInt : 60
Variable definitions
The following table describes the variables for the ipv6 pim command.
Variable |
Description |
disc-data-timeout <5-65535> |
Specifies the duration in seconds to discard data until the switch receives the join message from the rendezvous point (RP). An IP multicast discard record is created after a register packet is sent, until the timer expires or the switch receives a join message. The default value is 60. |
enable |
Enables PIM globally on the switch. The default is disabled. |
fwd-cache-timeout <10-86400> |
Specifies the forward cache timeout value. The default value is 120. |
join-prune-interval <1-18724> |
Specifies the duration in seconds before the PIM router sends out the next join or prune message to its upstream neighbors. The default value is 60. |
mode <sparse> <ssm> |
Configures PIM mode on the switch. The default value is sparse. |
register-suppression-timeout <10-65535> |
Specifies the duration in seconds the designated router (DR) suppresses sending registers to the RP. The timer starts after the DR receives a register-stop message from the RP. The default value is 60. |
static-rp |
Add new static-rp entries and enable static-rp. |
unicast-route-change-timeout <2-65535> |
Specifies the duration in seconds the switch polls the RTM for unicast routing information updates for PIM. The default value is 5. |
