Enable the collection of IPv6 multicast route statistics.
- In the navigation pane, expand the following folders: .
- Click IPv6 Mroute.
- Click the Globals tab.
- In the StatsEnabled field, select the option to enable or disable the collection of statistics.
- Optional: To clear the statistics, click StatsClear.
- Click Apply.
Globals Field Definitions
Use the data in the following table to use the Globals tab.
Field |
Description |
StatsEnabled |
Displays whether the multicast route statistics is enabled. |
StatsClear |
Clears the multicast route statistics. |
