Enable the access policy feature globally to control access across the switch.
You can create an access policy to control access to the switch. An access policy specifies the hosts or networks that can access the switch through access services; for example Telnet, SNMP, Hypertext Transfer Protocol (HTTP), and remote login (rlogin).
Rlogin is only supported only on VSP 8600 Series.
