Use the following commands to check TLV information.
For a Layer 3 VSN multicast, TLV 185 on the BEB where the source is located displays the multicast source and group addresses and have the Tx bit set. Each multicast group should have its own unique data I-SID with a value between 16,000,000 to 16,512,000. TLV 144 on the BEB bridge, where the sender is located, has the Tx bit set. All BEB bridges, where a receiver exists, have the Rx bit set.
  1. To enter User EXEC mode, log on to the switch.
  2. Display IS-IS Link State Database information by TLV:
    show isis lsdb tlv <1–236> [sub-tlv <1–3>][detail]
  3. Display IS-IS Link State Database information by Link State Protocol ID:
    show isis lsdb lspid <xxxx.xxxx.xxxx.xx-xx> [tlv <1–236>] [sub-tlv <1–3>] [detail]
Display TLV information for a Layer 3 VSN with IP Multicast over Fabric Connect:
Switch:1# show isis lsdb tlv 185 detail
			ISIS LSDB (DETAIL)
Level-1 LspID: 000c.f803.83df.00-04 SeqNum: 0x000002eb Lifetime: 1113
Chksum: 0x7e3b PDU Length: 556
Host_name: el2
Attributes: IS-Type 1
TLV:185 SPBM IPVPN :
	VSN ISID:5010
	BVID :10
		Metric:0
		IP Source Address: 192.0.2.10
		Group Address : 233.252.0.1
		Data ISID : 16300011
		TX : 1
		Metric:0
		Group Address : 233.252.0.3
		Data ISID : 16300013
		TX : 1
		Metric:0
		Group Address : 233.252.0.5
		Data ISID : 16300015
		TX : 1
		Metric:0
		Group Address : 233.252.0.7
		Data ISID : 16300017
		TX : 1
		Metric:0
		Group Address : 233.252.0.9
		Data ISID : 16300019
		TX : 1
		VSN ISID:5010
		BVID :20
		Metric:0
		Group Address : 233.252.0.2
		Data ISID : 16300012
		TX : 1
		Metric:0
		Group Address : 233.252.0.4
		Data ISID : 16300014
		TX : 1
		Metric:0
		Group Address : 233.252.0.6
		Data ISID : 16300016
		TX : 1
		Metric:0
		Group Address : 233.252.0.8
		Data ISID : 16300018
		TX : 1
		Metric:0
		Group Address : 233.252.0.10
		Data ISID : 16300020
		TX : 1
