Viewing ACL Statistics
Graph statistics for a specific ACL ID to view default statistics.
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select an ACL.
- Click Graph.
- You can click Clear Counters to clear the Statistics fields.
Statistics Field Descriptions
Use the data in the following table to use the Statistics tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
MatchDefaultSecurityPkts |
Shows a security packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultSecurityOctets |
Shows a security byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultQosPkts |
Shows a QoS packet count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchDefaultQosOctets |
Shows a QoS byte count of traffic that does not match an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalSecurityPkts |
Shows a security packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalSecurityOctets |
Shows a security byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalQosPkts |
Shows a QoS packet count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
MatchGlobalQosOctets |
Shows a QoS byte count of traffic that matches an ACE rule or hits the default action if count is configured in the ACL global action. |
