Display relay information to show relay information about DHCP routes and counters.
For scaling information on DHCP Relay forwarding (IPv4 or IPv6), see Release Notes for VOSS.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1#show ip dhcp-relay interface
Port Dhcp
PORT VRF MAX MIN ALWAYS CIRCUIT REMOTE TRUST
NUM NAME ENABLE HOP SEC MODE BCAST ID ID CIRC
Vlan Dhcp
VLAN VRF MAX MIN ALWAYS CIRCUIT REMOTE TRUST
ID NAME ENABLE HOP SEC MODE BCAST ID ID CIRC
All 0 out of 0 of Vlan Dhcp Entries displayed
Variable definitions
Use the data in the following table to use the show ip dhcp-relay command.
Variable |
Value |
vrf WORD<1-16> |
The name of the VRF. |
vrfids WORD<0-512> |
The ID of the VRF. The value is an integer in the range of 0–512. |
Use the data in the following table to use the show ip dhcp-relay interface command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
[vlan <1-4059>] |
[vrf WORD<1-16>] |
Specifies the name of the VRF. |
[vrfids WORD<0-512>] |
Specifies the ID of the VRF. The value is an integer from 0– 512. |
