This procedure does not apply to VSP 8600 Series.
You configure RADIUS secure profiles with certificate information, certificate key information, and password information, which enables RADSec peers to establish connections.
The following table defines parameters for the radius secure-profile command.
| Variable | Value |
| WORD<1-16> | Specifies the RADIUS secure profile name. |
| CA-cert-file WORD<0-128> | Specifies the full file path of the certificate authority (CA) certificate. |
| cert-file WORD<0-128> | Specifies the full file path of the server certificate. |
| key-file WORD<0-128> | Specifies the full file path of the private key file. |
| WORD<1-128> | Specifies the file name. |
| key-pwd WORD<0-255> | Specifies the private key password. |
