View the maps of network layer address to physical address to interface.
The probe adds entries based on the source MAC and network addresses in packets without MAC-level errors.
Switch:1# show rmon address-map
Rmon Address Map Table
PROTOIDX HOSTADDR SOURCE PHYADDR LASTCHANGE
1 192.0.2.11 2060 b0:ad:aa:42:a5:03 10/09/15 17:30:41
Job Aid
The following table describes the fields in the output for the show rmon address-map command.
Parameter |
Description |
PROTOIDX |
Shows a unique identifier for the entry in the table. |
HOSTADDR |
Shows the network address for this entry. The format of the value depends on the protocol portion of the local index. |
SOURCE |
Shows the interface or port on which the network address was most recently seen. |
PHYADDR |
Shows the physical address on which the network address was most recently seen. |
LASTCHANGE |
Shows when the entry was created or last changed. If this value changes frequently, it can indicate duplicate address problems. |
