Configure Endpoint Tracking visibility mode on the
switch.
- In Extreme Management Center, configure your third-party virtualization platform,
and the RADIUS server used for Endpoint Tracking authentication. For
information about configuring Extreme Management Center, see the Extreme Management Center
documentation at https://www.extremenetworks.com/support/documentation/.
On the switch, add and configure the RADIUS server as configured in Extreme Management Center.
Create and enable Endpoint Tracking on interfaces.
Enable Endpoint Tracking globally on the
switch.
Enable visibility mode to allow MAC learning on static S-UNIs for Endpoint Tracking.
Enter Global Configuration mode:
enable
configure
terminal
Enable Endpoint Tracking visibility mode on the
switch:
endpoint-tracking
visibility-mode
