Reset an ACL to change the ACL name to the default name and the filter ACL mode to a default of enable.
Variable definitions
Use the data in the following table to use filter acl command.
Variable |
Value |
<acl-id> |
Specifies the ACL ID. Use the CLI Help to see the available range for the switch. |
enable |
Enables the ACL state, and all associated ACEs. Enabled is the default state. |
matchType <both|terminatingNNIOnly|uniOnly> |
For inVsn ACL types, specifies the match type to associate with
the ACL. Valid options are:
name WORD<0-32> |
Specifies an optional descriptive name for the ACL. |
type <inVlan|inPort|outPort|inVsn> |
Specifies the ACL type. The values inVlan, inPort, and inVsn are ingress ACLs, and outPort is an egress ACL. A port-based ACL has precedence over a VLAN-based ACL. |
