BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
BFD provides a failure-detection mechanism between two systems. Use the following procedure to enable BFD globally.
Enabling BFD globally does not establish a BFD session. To establish a BFD session, you must also configure BFD at the interface level and at the application level.
enable
configure terminal
router bfd
router bfd enable
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#router bfd Switch:1(router-bfd)#router bfd enable
