Perform this procedure to view inventory attributes for vendor-specific call server information.
- Select Vendor Specific.
- Select the Call Server tab.
Vendor Specific Call Server Field Descriptions
Use the data in the following table to use the Call Server tab.
Name |
Description |
CallServerNum |
Specifies the call server ID. |
CallServerAddressType |
Specifies the IP address type of the call server. |
CallServerAddress |
Specifies the IP address of the call server. |
